Sok it to me ********s!!
View the thread, titled "Sok it to me ********s!!" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Couldn't get boards up upstairs without dismantling a bedroom full of built in furniture. This was a bare bones budget install hence the main HE boiler. I'd normally fit the filter in the airing cupboard but no room to move in there.
dont use a torpedo level if you want good straight pipework always level the clips then add pipe easist way under a boiler is strike a center line and measure of each side ,youll most times already have a centerline from hanging the jig just take it down to the level of the lowest clipthen strike two lines level where the clips are going and measure of same spacings as the boiler pipe centers
Not gonna work with gas capped? Bit of a basic fault? But a spirotec? Crossovers look tidy. Would have run hot round under flow parallel to gas and tied it in higher up and fitted a doc .
This is a redundant gas supply. A new gas meter is outside now. The customer wanted the spirotech, it wasn’t me.
Reply to the thread, titled "Sok it to me ********s!!" which is posted in UK Plumbers Forums on Plumbers Forums.
Kyle87,
TBServices,
