G
gjcone44
hi i am a spark, who has fitted solar pv on south facing roof.i am now looking at getting solar thermal, to supply my hot water ( just for upstairs, one shower and 2 sinks)have got combi boiler worcester, 30cdi. but dont want to get involved with that. have 2x2mts, on south facing roof, but also have a hip roof facing west, would like to fit panels / tubes, on both have plenty of room in loft for 250l tank, question is would you fit to separate systems, to feed a twin coil tank or would it be better to link the 2 together, and supply single coil tank, the solar experts advice would be appreciated :25:
Use Ecotube you'll only need 6 tubes, Even on a correctly designed system stagnation will occur it won't damage the system but will have an effect on the glycol so always use a good quality one
[h=3]
They are efficient I was suprised you need so few tubes but they are massive must be at least 100mm but they do work well
The Ecotube performance versus their five main competitors
- based on performance output per kWh per m²[/h]
[TABLE="class: tableborders, width: 100%"]
[TR]
[TD="width: 211"]*[/TD]
[TD="width: 211"]kWh/m²[/TD]
[TD="width: 211"]Relative Performance[/TD]
[/TR]
[TR]
[TD="width: 211"][/TD]
[/TR]
[TR]
[TD="width: 211"]Ecotube DF 100[/TD]
[TD="width: 211"]727.00[/TD]
[TD="width: 211"]100.00%[/TD]
[/TR]
[TR]
[TD="width: 211"]Baxi DF100 20[/TD]
[TD="width: 211"]704.02[/TD]
[TD="width: 211"]96.8%[/TD]
[/TR]
[TR]
[TD="width: 211"]Kingspan DF100 20[/TD]
[TD="width: 211"]699.11[/TD]
[TD="width: 211"]96.1%[/TD]
[/TR]
[TR]
[TD="width: 211"]Viessmann VT200[/TD]
[TD="width: 211"]682.14[/TD]
[TD="width: 211"]93.8%[/TD]
[/TR]
[TR]
[TD="width: 211"]Valliant VTK 1140[/TD]
[TD="width: 211"]642.89[/TD]
[TD="width: 211"]88.4%[/TD]
[/TR]
[TR]
[TD="width: 211"]Worcester Bosch T3[/TD]
[TD="width: 211"]539.84[/TD]
[TD="width: 211"]74.2%[/TD]
[/TR]
[/TABLE]
As you will see from the adjacent
chart the Ecotube DF100 has been proven to be the highest performing panel in the UK.
*All figures taken from T-Sol simulation design software – January 2011
Click here for RHI information [PDF]...
[h=3]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[/TABLE]
What kind of money ate they mate pm me if you don't want to post it
Qualities good used these on a flat roof install some sort of vinyl/rubber, we couldn't pierce the roof to get fixings these tubes just lay on pads when installed on a flat roof so installation was a piece of pish got some pictures somewhere will try to upload if I can find them
Where did the pipes go?
