View the thread, titled "Soldering wet pipes?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Try using earthing sleeve or preferably a clear small hose suck water out thats what I often do 😀
Mind you tried syphoning a bog yesterday 😱 It worked but did gag a bit Yuk.
your not real dude,
your not real😛😛😛😛
Redsaw the job needed to be done and since I lost my van tools are all over the show only today have I started to be able to get some organisation.
I must say though I did feel the need to floss and brush my teeth aftewards LOL 😀 But it was all worthwhile £150 for an hour is pretty good going.
An old guy I first did some work with swore by the bread trick, until it didn't come out the kitchen tap and he had to provide a new set to keep the customer happy
When useing the bread trick it is essential afterward to let the flow remove the bread! Taps and inlet valves will fail otherwise.
Reply to the thread, titled "Soldering wet pipes?" which is posted in UK Plumbers Forums on Plumbers Forums.
