T
trigger25
I've just bought some solvent weld pipe and connectors and was wondering how far the pipe has to go into the connector. As this is my first attempt at solvent welding I want to get it right. The pipe has been cut with a Rothenberger plasticut tool so the pipe end is burr free.
My pipe is 21.5mm overflow and the connector has a ridge 25mm inside which I assume the pipe has to butt up to but when I push the pipe in it only goes in as far as 22mm. The joint is quite tight as a dry fit, will this loosen up when I apply the glue?
Thanks in advance
Trigger
Thanks in advance
Trigger
