View the thread, titled "some tool recommendations please" which is posted in Plumbing Tools on UK Plumbers Forums.
armyash
Subscribed
Just wondering what SDS drills some of you use, if anyone can recommend me something (£200 budget) I will hopefully get something in the next few days.
Also what drill bit set would be worth getting?
what hole cutter set can be recommended?
what size hole cutter for flues 110mm?
It will be for drilling new flue holes when neccessary, and any other wall drilling that needs doing that requires it.
Registering with GSR next week, i'm using the guys tools I work with at the moment but want to get more of my own stuff together.
you realy cant use the same drill for everything for 110mm cores you need a dedicated drill like this Brand New!- Makita 8406/1 850W 110V Diamond Core Drill | eBay
the price of a new one exceeds your budget and its not realy good for day to day work
if i had your budget id look at starting with a 2kg sds corded drill which do everything except the big cores and hire the core drill as and when you need it till you can afford one
people ive spoken to now buy the professional range from wickes or b and q with a long gaurantee and take them back when they burn out
Not sure how helpful this is but I bought a decent 18v drill and ensured I had a range of bits up to about 10mm.
Then I bought the cheapest SDS I could find (£30 for a Titan) and bits as I required them. I've managed without a 110mm core cutter as someone's had one whenever I've required one. It took me a while to buy a 54mm diamond core bit and even longer to buy a 32mm masonry bit.
In my first two years I probably spent around £50 on my drill and bits and now seem to buy another bit every nine months or so.
I was wary of buying too much clobber to start with and end up not using half of it. For example, in my cheap plumber's drill bit set from Screwfix (£18?) I've only used 3 of the 7 pieces in 5 years.
It's so tempting to buy huge amounts of all sorts and not use half of it. Additionally, you're lugging a large amount of dead weight in the van which affects fuel consumption. If you leave it at home until you require it, you can bet your bottom dollar (when you're an hour away) you put it in the van last week. With fewer tools, you'll carry them all, use them all more frequently and have less useless weight.
PS - five years on, my Titan's still working sufficiently. I know there are better drills costing more but I've made better use of that money.
Thanks for the info everyone!
I have drills for day to day stuff but was looking for something specifically for when the heavy duty drilling is required. I'll have a look around, my budget can be stretched a bit, i don't want to go crazy buying the best of everything just starting out but i'm not going to scrimp either as I'll end up paying out twice as things pack up.
That's the sort of thing I got.
If you're going cheap I'd buy new because a used one like that might have a broken clutch. Even my battery drill spins me round in circles if I'm not careful. A 240v can do a fair amount of damage to a weed like me.
Haha all I have used so far is a 240v it was a good work out! if that that type of drill that I posted would be good enough for heavy duty drilling then I'd get something similar but I will buy new and get something decent.
Of all the SDS drills I have used; I've liked, the Milwaukee HD28 cordless hammer (£684), the most. Out of my price range to own one myself (at the moment)
I have a DeWalt 110v SDS drill (£100), as for bits Rothenberger 12pc Dry Diamond Core Kit (£125)
Thanks, good enough to drill holes in walls for flues?
Drills (Diamond Core)
The dewalt is on budget and can be used for code drilling as it has a nice 1300w motor and can also be used for normal drilling only down side to these style drills you dont get sds
but as said i find its best to keep 1 drill for coring and another for general drilling and demolition.
ps if your thinking of ordering i use these guys regularly and have never had a problem.
You really need 2 different drills one for normal work and a dedicated one for cores but as you are on a budget pick a decent sds.
Any sds will drill std holes in anything and will do most sizes of tungsten cores but to use it for diamond coring over about 60mm you need something with a strong motor and a fairly high speed (and a bit of patience to hold on while it takes it time getting through). Core drilling big holes puts a lot of strain on a drill. If the motor is not powerful enough the drill will burn out after a few uses, if it is a cheap one the bearings will go on it.
Look for clearance or ex demo stuff. There are some good prices if you look around.
Something like this would be a good choice at a very good price
Metabo UHE28code 110v [CL] Multi-function SDS hammer £124.95
That one is 110v tho but you can pick up a tranny cheap.
117mm is the core size you want for flues.
Titan Sds Hammer Plus | eBay
just picked a random drill from ebay, not getting it but would something like this be suitable for drilling flue holes?
thats no good for core drilling as i dont think you can switch the hammer action of apologies if thats not true certainly good for everytyhing else as it dooes have roto stop for light chiseling
not having a sds drill is a big mistake as its invaluble, fast change of drill and never slips before we had sds ity was a constant battle to stop drills slipping and once theve sliped the sharp bits are like razors and attracted to hands and fingers like bees to honey thats without the stilson gouges on the chuck plus sds bits last for ever if you dont hit anything metal
Plenty to think about thanks guys, working all weekend but got a couple of days off next week so going to go and get some new tools/accessories. Before I pay out for an SDS I'll pick out a couple and get some opinions on here if that's ok.
I managed with my old sds (bosch) for ages , doing every thing, though have now invested in a dedicated diamond core drill, the differance in night and day in terms of cutting speed. Though on a budget you can get by.
The Sparky above is an excellent CORE drill and hasn't let me down. Great value for money.
My SDS is a Dewalt that sails through walls like they aren't there and takes 1m long 25mm drill bits... perfect for outside taps in Victorian houses.
DeWalt D25123K-LX 2.6kg SDS Plus Hammer Drill 110V | NoLinkingToThis
Best to buy 110v now instead of having to change everything later, essential if you do site work mate.
why not get the sparky core drill and this
Titan TTB277SDS 3.5kg SDS Plus Rotary Hammer Drill 230V | NoLinkingToThis
seems to get good reviews and will have a years guarantee minimum and falls in your budget
personally id stretch the budget for the makita as a good core drill is so diffent to making do with something thats not realy designed for coring
Reply to the thread, titled "some tool recommendations please" which is posted in Plumbing Tools on Plumbers Forums.
Thread starter
armyash
Subscribed
Joined
Location
Kent
Thread Information
Title
Prefix
N/A
Forum
Plumbing Tools
Start date
Last reply date
Unsolved
Thread Tags
Tags Tags
tool
armyash,
Phil,
