M
mchandler
Hi all, I'm doing my work placement / portfolio working towards my Domestic Gas ACS. I've just serviced my Flavel Diamond 6.9 kW inset/DFE fire. No problems, pressure, gas rate, flame picture all ok. Came to do spillage test (after 5 mins) and I got some spillage. Re-tested several times, same result - most smoke drawn but about 5-10% comes back into room. I noticed in MI a whole page insisting that the unused gas supply apertures in the firebox bottom must be taped up with foil tape which I did (they were all open). My thoughts are that this may have created falsely large draft and hence passed spillage test on installation (3.5 yrs ago)? I have a pre-cast chimney/flue set-up (house built ca. 1996). Depth of opening to firefront fascia is about 300mm. There is a false chimney breast of blockwork which forms a ledge/possibly lintel in the builder's opening of approx 20 cm depth in front of the flue block opening and directly above (4-5cm) the fire opening. This doesn't seem a good set-up as it must be affecting/slowing draw? (by the way flue flow / smoke test was fine). Clearly the current set-up isn't providing enough combustion air / flue draw. So I've ID'd my own fire!! Would be grateful for advice on options/next steps....?? many thanks.
