N
niallcook
Hi all. Am getting conflicting advice from pump manufacturers so thought I would test the experience of the people who do this for a living.
I am installing a steam shower cabin which requires a hot and cold supply of between 2 and 3 bar and a flow rate of at least 7.5 litres/minute. Per the manufacturer's instructions, I'm planning to feed the steam generator separately from the mains cold so the pump will just be serving the main shower assembly (hand shower, monsoon overhead shower and 6 body jets). The pump will be positioned around 2.5m below the header tank and about 0.5m below the bottom of the hot water cylinder (and 2m below the top of the shower cabin).
I already have a dedicated cold feed from the header tank from the previous shower (in 15mm) and can connect into the hot feed as it enters the bathroom (15mm or 22mm) and before it branches off to the bath and two basins. I have 2 x 15mm pipes running under the floorboards from the pump location to the shower (about 2.5 metres away).
The problem I have is that the pumps I'm being recommended have 22mm connections whereas most of my pipework on both inlet and outlet side is 15mm.
Is it acceptable to take the pipework up from 15mm to 22mm before the pump inlet, and then back down from 22mm to 15mm on the outlet side?
Or would it be better to try and find a pump with 15mm connections? If so, can anyone recommend one for my purposes?
If I can at all help it, I'd rather not have to redo all the pipework in 22mm.
Thanks.
i'd forgotten that didn't reread the whole thread lol. in that case feed would have to be in 22mm the whole way otherwise you won't get full benefit from your shower. apologies for misinforming .you
For what it's worth, I can't have them all going at once but only switch between them. Anyway, have decided the best bet is to run dedicated 22mm pipework all the way from the CWST and HWC to the location in the bathroom where I'd originally decided to have the pump, and be done with it (I hope). From pump to shower (2m) will use 15mm as it has to drop down for the shower connections anyway.
Of the pumps I've been recommended, does anyone have a favourite?
  • Salamander ESP 100 CPV Twin
  • Salamander Force 30 TU
  • Stuart Turner Monsoon 3.0 Bar Universal
