Matt0029
1,245
110
63
37
leeds
Heating Engineer (Has GSR)
When testing the safety device on a combi boiler (ideal instinct). I know to make a fault, by turning off the gas supply. If the safety device is working correctly the boiler will go to lock out within 2 minutes and won't fire again once the gas is reinstated without resetting the boiler. What is the correct/best way of checking the gas valve is not passing once it goes to lock out?
Would a tightness test at the meter when the boiler goes to lock out after 2 minutes be adequate to test this?
