The great big plumbers wish list thread.
View the thread, titled "The great big plumbers wish list thread." which is posted in UK Plumbers Forums on UK Plumbers Forums.
a wrachet spanner that works , heated windscreen for the van is a must !!! an app that can turn heating on from work ......
an app that tells customer to call for service when time is due
Wratchet spaner try britool
there is an app for turning home heating on if that's what you mean.
drayton do a programmer with a service indicator
Laser powered laser guided flue-hole cutting limpet. Stick it on, switch it on, get on with something else
A machine to straighten out coiled up 10mm.
An automated pipebender that can create perfect offsets and crossovers.
A junior hacksaw that cuts straight.
A burn mat that doesn't divert flames elsewhere.
A machine to straighten out coiled up 10mm. Didn't someone show one on here recently.
An automated pipebender that can create perfect offsets and crossovers. They're available but incredibly expensive.
A junior hacksaw that cuts straight. I've got one, it's goog thirty years or more old and you can tighten the blade like in a large hacksaw. Sandvik make the 268 junior which features a screw to tighten the blade, don't know if it's as good as mine though.
A burn mat that doesn't divert flames elsewhere.Can't help with this one but I've found if you use Mapp you can use a smaller flame.
well i think your all just a lazy set of ungrateful so and so`s i tell ya you wanna be great full of the technology we have - WHEN i was a lad back in the day of plumbing you had to..................... never mind
Hands that were similar to a Swiss Army knife! All you needed was there in your fingers; adjustable spanner, slotted driver, pozi driver, torch, nose picker, arse scratcher, bleed key, rad tool, possibly even a phone built into the palm of your hand!!
You had to what? Mine the lead yourself and carry it on your back across the great viaduct then swim to Pompeii?
At the moment I'd settle for some work. Had to resort to 'damsel in distress' jobs! Putting up shelves, putting together flat-pack, laminate flooring, decorating etc..............:disappointed:
Sorry to hear that Sid.
I would like a zero gravity tool bag.A bit like the hover boards in back to the future.
So you could pull in a 50KG tool box and not have to go out to the van three times for a 'just' job.
Reply to the thread, titled "The great big plumbers wish list thread." which is posted in UK Plumbers Forums on Plumbers Forums.
Guest123,
theanalyst,
