Thermostatic shower making high pitched whistle / whine
View the thread, titled "Thermostatic shower making high pitched whistle / whine" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
Hi all, we have a Quadrato shower from Victoria Plum. Looks like a copy of the Bristan Quadrato fed off the boiler.
We're having some issues with it making a high pitched whine / whistle sound and can't trace the source. It's the same using either the main showerhead or switching to the hand held one. The sound changes if the water temp dial is turned which initially made me think it was the thermostatic valve. The nearby sink (also on a mixed tap) is fed off the same pipework from the boiler downstairs and is totally normal in use.
So far, I've tried the following with no success:
  1. replacing the thermostatic cartridge. No change.
  2. dialling the mains water pressure up and down at the mains stopcock. No change.
  3. checked the shower pipework and heads for limescale build up but all clear.
Maybe related but last year we had some work done downstairs. A short length of the H&C pipes were modified as they were in a boxed in section and we wanted to bury them flat to the wall behind new plasterboard. The stopcock was moved about a metre away to also bury that in the wall (behind a hatch). At the same time, wet underfloor heating was installed downstairs so the boiler also supplies that via a manifold. Could either of these works have created a related issue? None of the other mixer taps in the house exhibit this behaviour.
What else can I try?
thanks!
@ShaunCorbs yes, only when the shower is running and seems to be hot water related as it's normal if run full cold. As the H&C pipes run up the living room wall behind the plasterboard it's noise in both the shower and living room.
Pressure is fine and I've tried adjusting the mains pressure at the stopcock but I'm not sure how (if) I can adjust the boiler pressure.
If the heating is running for either the UFH or rads (regardless of the shower being in use) that's normal, no excessive noise.
I would suspect the shower then best option is to go for a decent one eg Bristan etc
Cheers @ShaunCorbs but that seems a bit excessive and with no guarantee of success if I don't know what part of the current shower has failed. The only other consumable part I can replace is the diverter, other than that it's essentially just pipes and heads.
I'm just trying to figure out if this is a known issue others have faced to learn how they resolved them.
Reply to the thread, titled "Thermostatic shower making high pitched whistle / whine" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
new666uk,
new666uk,
