Things i need for a Plumbing tool kit
View the thread, titled "Things i need for a Plumbing tool kit" which is posted in Plumbing Tools on UK Plumbers Forums.
pana37
hi all after posting on this great forum i have decided to go for Copper pipes to fit a totally new central heating. before anyone says i wont be touching any gas!
already have 22mm and 15mm pipe slice.
Question i wanted to ask is.
i need to buy Lead free solder and Flux with a built in brush, are there any particular brands i should go for? or are they all the same?
looking to buy map gas from toolstation linky
what other things i need besides normal diy tools
thanks in advance..
It's like riding an old bike,whatever would we do without capillary attraction, three wheeled bike!!!😱mg_smile: it's when you get in those awkward
spaces where the experience will count, don't burn everything around you
yes going to start this v soon thanks Keefy
Cut a length of pipe up into small sections, say an inch or two per piece and join then together with couplings. Practice soldering from below too. Remember to remove the flame before applying the solder.
There's so much to learn if this is your first time doing such a job but if you're willing to listen and take the advice offered by the members here you should be okay. You could probably do with getting your camera out to keep us updated.
Good advice Keefy, but please not on film I don't like seeing grown men cry..:19: Push fit rules OK, did I just say that :bigcry: copper not plastic
http://www.youtube.com/watch?v=7qbq2Z5_LUY
http://www.youtube.com/watch?v=JufNYNnxLrw
Top Advice Keefy, will take pics
was thinking how does end feed and solder ring differ besides 1 doesnt have solder and other has. is one better than the other?
With solder ring fittings you just apply heat until you see a nice ring of solder appear but they're more expensive than endfeed.
Everyone has their preference with flux. I use La-co flux, but beware it seems to run more than other fluxes and it will turn your clothes purple and your hands green! Make sure you wipe your joints after as it is will eat through them eventually.
Don't buy Mapp gas, its too hot for small pipes, normal blue bottled propane is more than adequate for upto 28mm pipe.
'Fings what I have in my tool bag:
Pipeslices
Adjustable pipe slice
Adjustable spanners (Daddy, Mummy and Baby size)
Water pump pliers, aka grips (as above)
Junior Hacksaw
Various size and length screwdrivers (flat and pozi)
Torpedo Level
Stanley Knife (other brands are available)
Hammer
Floorboard lifter
Half round file
Wood Chisel
Multimeter
Wire cutters
Plus a few gas related items
It also reduces your lung function by 2% everytime you use it XD
i used it once, great flux but man all i tasted for hours after was laco from the smell !!
Get a pair of benders ifyou don't mind losing a few quid in the learning process.
[video=youtube;cMAgArlo_1g]http://www.youtube.com/watch?v=cMAgArlo_1g[/video] i see what you mean could save a few quid in the long run and less joints less chance of leaks also, i guess will need practice of getting it right not sure if this will work on tight corners
Don't know about anyone else but that's not really a deburring tool, it might be okay on a cut done by a hacksaw but for a pipeslice cut I'd use one of these.
I didn't say it was deburring I saw this being used to clean inside the fittings prior to fluxing to provide a key? However I will need a deburring tool so will look at the product on that link, hasn't had good reviews though
Heat mat
footprints
small damp rag for cleaning up joints
spray bottle of water just incase
deburrer 15mm 22mm 28mm
GOOD blow tourch and mapp gas heats quicker
jimmy bar
cheap saw
flux brushes more then one
benders
spade drill bits
sds drill sds bits raw plug size and 16mm and 24mm long sds bits
core drills
tape measure
pencils
sharpie marker pen to mark pipes
hammer
cordless
open tote tool bag to carry it all in 😛unk:
hire or borrow a pipe tester wet or dry
radio
pipe clips fittings
PIPE LOL
lagging
level
angle drill attachment if your posh
camera for our pleasure
pain killer kneeling pad or knee pad or even propper work bottoms with knee pads
id use lead free solder
ptfe
paste
grips
a couple of burn mats wont go amiss i dont often use them as you can usually angle the flame away but knowing where the flame will bounce takes experiance
Reply to the thread, titled "Things i need for a Plumbing tool kit" which is posted in Plumbing Tools on Plumbers Forums.
pana37,
supper plumb,
