Sep 4, 2010
73
My customer had a broken diaphragm on a syphon that operates with a handle at the front of the cistern. Instead of replacing the plastic part he changed the entire syphon - 3 times - but the same thing keeps happening. When you pull up on the wire the syphon works but it doesn't dump the water from the cistern. Instead it just trickles out like a newer syphon that overflows into the pan until the water has been used, then it stops and refills fine.
For the life of me I can't work out why the syphon only works to a certain extent. One thing I've noticed is that when you flush water comes out of the rod housing (the rod on the diaphragm pull) and I think this should go down the syphon - but this has happened on all 3 new syphons.
Any takers?! Hopefully it's just me having a long day and overlooking something obvious.
Check outlet on siphon could be blocked and check that the plastic cap is inserted which converts from 6L flush to a 9L flush. But my guess would be that the actual siphon has a blockage or the outlet on the pan where the siphon sits through (where your doughnut sits)
Reactions: 2 people
If the syphon has been changed then changed again it's unlikely to be faulty, if the first one failed because the diaphragm was damaged it's likely that there is a piece inside the pan, take the cistern off and pour water into the pan at the doughnut, if it's clear it will pour round the rim like a flush, if it backs up it's blocked, sometimes pouring the water in here dislodges the bit of diaphragm (or lid from bic type razor) you might need to poke around in it to dislodge the blockage
Reactions: 2 people
I had a similar problem, replaced a siphon but it wouldn't flush properly. On the end of the old siphon was something that appeared to be redundant. Turned out it was along the lines of a dip tube which helped the water flow into the bowl. Can't remember the exact name but solved the problem. Could be an idea
Not at all redundant......it was a syphonic aspirator which is needed to clear the bowl properly.
Customer has replaced the syphon 3 times and probably thrown the old bomb away. It would be really really bad luck to get 3 new syphons all failing, still reckon its a syphonic.
Had toilets before where entry into the pan from cistern is shallow and the flush valve or syphon protrudes to far and limits the spread of fluid. Fix cut down the threaded tube.
I'm replying to everyone - hopefully as I'm not quite sure how this page works yet - just to say thanks for your help with the syphon. It's sorted now and the reason it didn't work was... the pipe and pan were blocked by components of a mobile phone!! Absolutely NO idea how that happened
Well I`ve heard of a "Burn phone" but that`s a new one on me!
1/2 point for me with "lid from BIC razor or similar"
Thank you
Its the new internet toilet. You can flush it from anywhere with your mobile 🙂
Not quite that simple mr G!
You need the BG hive
BG sanitary appliances annual service contract
BG platinum controls package
BG app and annual subscription for the IT support
And the £5000.00 armature gas loo. With I pad doc and LED illumination
