Too much air
View the thread, titled "Too much air" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
A
Asare Thagu
Hi there, I have too much air in the radiators, have to bleed every day to get it rght. Its vented system with F/E cistern on the loft and boiler under stair. Please advice..
corrosion issues try (very carefully) setting fire to the air next time if it burns its hydrogen a by product of corrosion failing that its a bad system design in either case you need to get a pro in to resolve your issues
I carefully tried to set a fire as Gas man said but there was no fire, which confirms it is not a corrosion issue but a bad system design. When thoroughly checking the system, the pump is not fitted wrong way round either, and threre is no myson aerjec installed anywhere. In my view, a pump which is installed closely to vent pipe which might be sucking air from it. Can it be the cause??
Reply to the thread, titled "Too much air" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
Asare Thagu,
kay-jay,
