Guest viewing limit reached
Tool for stubborn tap head gear?
View the thread, titled "Tool for stubborn tap head gear?" which is posted in Plumbing Tools on UK Plumbers Forums.
JCplumb
As the title suggests. Anyone know of a decent tool for removing a really stubborn tap head gear?
I've usually managed to crack them after a while but one job a couple of months ago had me beat, the customer had these really old taps and he loved them and I was close to threading the 'nut' part of the tap head trying to remove it. I actually admitted defeat on that one but have promised him I will be back when I figure out how to get it off. I was there to replace a valve on his toilet but he mentioned the dripping taps and said that 2 other plumbers had failed at removing them before me.
I remember seeing something on dragons den a year or so ago, it looked decent to be fair but was slated by the dragons.
Did have 28mm copper pipe used on some taps.
But had a bigger tap and needed LCS I had tucked away, I thought it was big enough but was only 1" so had to upscale with reducer and a bigger spanner on headgear.
Come off o.k. though, leverage.
All this freeze talk spray makes me laugh, no way is it going to freeze or shrink anything... I have had a can in the van for a couple years I normally use it to try & free a bolt etc but I doubt very much it's freeze / shrink abilities... I'd imagine you'd have to use half a can for that & im far too tight fisted for that! Better off getting the blowlamp on it & doing the opposite ??
Impact socket set and impact driver, 17,18,19,20mm will do most taps and stopcocks.
Holding a backnut box spanner as a brace so the tap doesn't move
I pull the guts out of 50-60 yr old taps with it on a daily basis
Reply to the thread, titled "Tool for stubborn tap head gear?" which is posted in Plumbing Tools on Plumbers Forums.
JCplumb,
SJB,
