Nov 28, 2018
53
21
Reading
General Plumber
Guys,
I am just changing my own heating system to a sealed system (not the hot water, just heating) because I added a circuit and needed to move the pump, now the Vent and F and E tank are on the pumped side of the pump.
Expansion vessel sized and fitted, and open vent sealed off with a bottle air vent, (or will be) but I have 2 questions...
1, can I use the F and E tank as a "top up bottle" instead of using a mains filling loop? Checking my understanding...I think I can, so long as I can fill the system, then seal it, I don't see an issue.
2, If so, can I simply use it manually, with a gate valve or do I need to fit a non-return valve and have automatic top-up, is this the best of both worlds, or does it just mask leaks? I think I can do either.
Two advantages as I see it...
1, minimum pressure, as only enough to fill the system is needed.
2, less work!! never a bad thing!
Thank you.
Know you need a proper filling loop and pressure gauge in with a built-in non-return valve the mains water I think your question shows you don’t really know what you’re doing have you thought about safety devices
Yes, there is a 3 bar pressure valve, in the garage where the boiler is, piped to outside, it's connected into the system with no valves along with the expansion vessel. There is a pressure gauge fitted at that point, next to the boiler.
I could connect a mains filling loop in at that point, but diagrams in the boiler MI show sealed systems with a top-up bottle, rather than a "proper mains filing loop", perhaps as I "don't know what I am doing" you could explain that to me....or explain why the boiler manufacturer doesn't know what he is doing???
  • Agree
Reactions: chris watkins
Just wouldn’t risk a pressurised system on an NRV not failing
I have fitted a complete system, with expansion vessel, blow off valve, piped to outside pressure gauge and a connection for the mains cold water filling loop.
My question was simply, can I fill that system from a top-up bottle, rather than the mains?
The boiler MI shows that I can.
The NRV on the F and E tank (top-up bottle) is to seal the system, not as any safety device.
You never mentioned that you’d fitted safety devices and stated yourself that you were looking for the easy route and because of the attitude on a forum where experts give their opinion free of charge I’m out!
My attitude?
The “” marks you seem to forget you’re on a forum asking what to do which implies that you don’t know? Correct? Anyway bye
An expert wanting to help may have said "have you thought about safety devices?" Someone with a bit of knowledge trying to big themselves up would have said "have you thought about safety devices, your question shows you don't really know what you are doing". I didn't say I hadn't piped it up in garden hose either! Your attitude stank. I was looking for answers based on experience so I can understand, and not just plumb by numbers. Your answer about needing a filling loop instead of answering my questions shows that is what you do, so I will wait for an expert. Thanks for your input though.
  • Optimistic
Reactions: Riley
Looking at your post in introdutions I can see that you are not the average diyer looking to save money and you are asking the Q to be sure of what you think will work.
Sometimes the odd " or ! can change the dynamics of the conversation so perhaps a cooling off period here would help matters and the thread can continue later?
Exactly, Shaun's reply was more what I would expect from polite society.
You can do but you need a nrv on the feed pipe also where's your blow off going ?
Thanks Shaun,
I have put the expansion vessel, supplied as a kit in the garage, connected directly to the boiler return. It is fitted with a 4-way manifold, into which is connected, the vessel, the boiler return the blow off valve and a connection for cold fill with a ball valve.
The system is not new, so I want to keep pressures as low as possible, but I am getting some pump-over because the vent and F and E tank are now on the positive side of the pump. It's major work to change that because of the pipework layout.
I would think that once the system is full and the top-up bottle disconnected, nrv in action or gate valve closed, or the mains filling loop disconnected, that the system would not know any different.
The gate valve would be just like the combined nrv/ball valve that came with the kit, but just a nrv would give automatic top-up, like a vented system?
Just looking for any reasons why I am wrong.
Using the existing F & E tank how would you achieve the initital system pressure?
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Edited
Scrap that question , it was open vented so won't have a minimum requirement.
Thanks Shaun,
What boiler you got?
Guys,
Thank you.
I have read your plans very carefully, I would make an initial,observation that 65% of all sealed unvented systems leak and lose pressure so an unconnected Top up bottle could be a pain, and mains water at pressure is very cheap.
Unless you are worried about wras regulation regarding seperation of drinking water etc. I can quote you chapter and verse if you need to know
I am a heating designer so can see where you are coming from.
But why design problems in ?
I also fail to understand the motivation behind your project
So,perhaps you might elabourate (they can’t touch you for elaborating I do it )
Rob Foster
