I have read your plans very carefully, I would make an initial,observation that 65% of all sealed unvented systems leak and lose pressure so an unconnected Top up bottle could be a pain, and mains water at pressure is very cheap.
Unless you are worried about wras regulation regarding seperation of drinking water etc. I can quote you chapter and verse if you need to know
I am a heating designer so can see where you are coming from.
But why design problems in ?
I also fail to understand the motivation behind your project
So,perhaps you might elabourate (they can’t touch you for elaborating I do it )
Rob Foster
Thanks Rob,
The house I bought in 1994 was a small cottage, with no heating or hot water. I installed a boiler in the cornerof the 8' x 8' kirchen and, because there was no space I put the cold water tank, f and e tank, hot water cylinder, pump and S plan valves in the loft.
Primary flow went from the boiler, past tje vent pipe, past the fande through the pump and into the S plan valves.
The house is 2.5 times the size now and what was the cornerof the kitchen is the middle of the lounge and the boiler is in the garage, which didn't exist back then.
I have added two radiators in the, now, kitchen, (to replace electric underfloor heating) and connected into the f and r primarys for 2 reasons. First, it saves ripping the house apart and second, so I can have it as a seperate zone. With the pump in the loft, A, the heating or hw would need to be on to get circulation so it could only be a zone that could be off, not on by itself. B, the circulation could/would bypass the boiler. So I moved the pump to the flow directly above the boiler. But that puts the pump before the vent and f and e connections.
Again, moving those involves pipe runs in the decorated part of the house, so I decided to make it a sealed system.
It's almost just an acedemic interest thing for me to know if I can use the f and e tank as a top up bottle, permanemtly connected via a nrv.
I have oversized the expansion vessel slightly to reduce the pressure rise and only filling to atmospheric pressure via the top-up bittle seems a good move too.
