View the thread, titled "Trappex Freebie pump rotation tester" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Do these actually show if the pump is rotating or just producing a magnetic field as the coil in t the motor is energised
Went to the pub for a couple of hours and missed all the freebie action! I'll try one out if any left.
Well you could always start taking delivery address's for the inline trapex filter just pop mine out to the same address as the pump tester,
kind regards.
Currently testing ,hopefully try to launch the Trappex centramag inline filter for April/May.But I will be giving 10 freebies away then , only on this forum.
Ferroli have been giving away filters, re branded no nonsense ones. Pile of poo.
I take the screw out and look down the hole " Am I daft " please don't answer the last bit, I have a mantelpiece clock that works under water, I must admit
I don't think I am keeping up with technology , am I slowing down or is click-nology speeding up. I have just applied to have 3 ph installed in my house so I would luv
one so I can test the tester.
Currently Trappex Centramag have teamed up with a new boiler manufacturer called Motan boilers .Motan boilers make it mandatory a Trappex Centramag filter is fitted on there system otherwise the warranty is void.They are the first boiler manufacturer that have made fitting a filter mandatory ,I am sure others will follow .
Reply to the thread, titled "Trappex Freebie pump rotation tester" which is posted in UK Plumbers Forums on Plumbers Forums.
Thread starter
Joined
Thread Information
Title
Prefix
N/A
Forum
UK Plumbers Forums
Start date
Last reply date
Thread Tags
Tags Tags
pump
bspareltd,
Ch4 plumbing,
