View the thread, titled "Trickling hot water bath tap." which is posted in Bathroom Advice on UK Plumbers Forums.
hi,
I bought a new build a couple of years ago and the hot water tap on the bath has always being a bit slow but about 2 days ago it has turned to a trickle which then starts to stop and starts trickling again at a very very slow rate.
All the hot water taps in the house work fine apart from this one the shower even works fine but this one hot tap does not,the boiler pressure is at a good level just under half way I think but Iam not sure if the hot water valve on underneath has being shut a bit I don’t know which one it is?
It’s a logic Combi ES30 I think and it’s just one bath hot water tap that is not working very well.
Thank you
Pushfit everything - what is wrong with these people, call themselves tradesmen..
Isolate both the hot and the cold valves.
The pipe entering the bottom of the tmv is the hot, connect this to the copper pipe going to the hot tap.
Disconnect one of the two elbows on the cold and cap off the pipe (I expect that tap mixes in the body and has no non-return valves).
Turn on the hot isolating valve BUT LEAVE the COLD OFF.
Test the hot tap.
If better flow, replace the TMV , whilst you are about it I would replace the two isolating valves with full bore valves.
Thanks Ben I’ll give this a try tomorrow morning I’ve being away recently so I have not being able to check the forum.. is there any bits I’ll need to buy before I try and connect the copper pipe to the one going into the TMV? To make sure the I get it to fit? Elbows or something like that? Also best way to get push fits off?
Reply to the thread, titled "Trickling hot water bath tap." which is posted in Bathroom Advice on Plumbers Forums.
