TRV problems high pitch squealing
View the thread, titled "TRV problems high pitch squealing" which is posted in Central Heating Forum on UK Plumbers Forums.
Good evening - I wonder if anyone can shed some light on this.
Squealing high pitch TRV's when reaching the required shut-off temp.
I understand its probably the pressure in the system making the pin in the TRV vibrate. Or pump turned up too high - which I guess would cause the same effect of raising the pressure.
Firstly I'm in France and have a new french (Frisquet) sealed system running at 1.3-1.4 bar.
The house was plumbed before we bought it by Spanish plumbers. French / Spanish - recipe for disaster. They cant even agree on the size of pipe they use!
So we're in copper 15mm.
The TRV valves are cheap Spanish ones. I would fit Drayton (and have fitted many of them in England with never a sound out of one) if I could find 15mm into half inch rad connectors (the spanish ones of course!)
So should I drain down again and get some more upmarket spanish valves - or get a degree in nuclear physics and turn the pump down a notch - except its a French pump buried within the boiler and seems to have no adjustment via the electrical input panel.
Things were easy in England - vented or pressurised, 15mm with olives. Easy. Here its 15mm 16mm 18mm and multi layer all in the same house - and a variety of different seals, rubber, plastic, long olives and string!
Has anyone had this amount of noise out of a TRV?
Any help much appreciated.
Hello and yes they are. TRV's on the flow side.
The balancing valves are at the bottom ( which are all 8mm allen key type and leaking coz they're the cheap spanish ones.) I need to upgrade those too - but I cant find the plastic olive fittings apart from on the cheap ones and the metal spanish long olives leak too.
I've never had so many drips out of a heating system in 40 years and I've fitted full systems in my first flats in London with not one drip.
As a temporary measure suggest reducing boiler flow temperature to say 50C which means TRVs opened more for same mean rad temperature, less squealing?. If not a combi you will then have to reduce the cylinder stat to 45C and boost the temperature to 60C once per week for legionella protection.
Reply to the thread, titled "TRV problems high pitch squealing" which is posted in Central Heating Forum on Plumbers Forums.
Rustynut,
Scott_D,
