View the thread, titled "Two seperate manifolds on two floors" which is posted in Water Underfloor Heating Advice on UK Plumbers Forums.
Hi
I installed ufh on two floors. My question is can I run two manifolds on two floors with one pump and mixing shunt?
How do I go about connecting the manifolds together, do I run a T straight after the pump before it enters the first manifold or do I connect the second manifold after it enters the first manifold?
This is what it says on danfoss website about the mixing shunt.
"These are designed for 1 to 3 floor heating circuits and contain both a small mixing shunt as well as 1, 2 or 3 group manifolds"
According to this its possible. Or am I misunderstanding?
What sizes are the manifolds? If they're under 12 ports in total you could run the system off one pump and have a T after the pump going to each manifold.
Reply to the thread, titled "Two seperate manifolds on two floors" which is posted in Water Underfloor Heating Advice on Plumbers Forums.
Thread starter
Joined
DIY or Homeowner
Thread Information
Title
Prefix
N/A
Forum
Start date
Last reply date
Thread Tags
Tags Tags
None
Yrys,
Yrys,
