UFH not working - suspect issues at manifold
View the thread, titled "UFH not working - suspect issues at manifold" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hello
As per title, the 3 zones of UFH to one manifold are not working.
All is good from an electrical perspective, i.e. the room thermostats are calling for heat, the UFH wiring centre is triggering the boiler, but simply no heat is coming from the floor.
What makes analysis difficult is 1) recently moved in and had the system turn off for long period whilst doing works 2) 2 of the zones are same room, large kitchen with aga oven releasing heat.
Assuming it's an issue at the manifold, what are the things I can test for? The flow meters are gunked up, could that be the cause or indicate whole system needs power flush? It has a grundfos motor but I can't hear anything, but same motor is on different manifold and is silent but working fine, how do I test if motor actually working?
Anything else I can cross off before getting someone out?
Thanks!!
Can you feel the pump working ?
Zones open / flow meters moving ?
The pump feels warm to the touch but it's not vibrating or anything. No lights. There is a settings lever on one side marked in Roman numerals "I", "II" and "III" (currently set to I) but I don't know what the controls.
The bottom left hand (zone 1) pipe is the only one warm, the top three pipes by actuators and other bottom 2 are not warm.
The flow meters arent showing any sign of movement. Zones indicating open on actuators
Grab a towel and open the front bleed screw is the impella turning if not use a flat bladed screwdriver to give it a spin
Aslong as there’s 240v at the pump
I'm also wondering, if the pin is up (as I can press down) then surely they should all be receiving hot water ie the flow pipes should be hot. But only the return pipe on the first port (bottom left) is warm
Have removed and serviced flow meters and actuators but issue remains and makes sense as above, actuators pins stuck open so if anything I should have had hot pipes from the off. So they work, pump works, there is hot pipework after mixing valve.
Last thing it could be is blocked loop (with sludge) or anything I've missed?
Only option is to now flush each loop via a hose pipe incase there’s air stuck
Started to flush and from what I've researched, I should leave first flow meter open and other closed. It's not overly clear but to do that I've unscrewed the glass portion as much as possible anti clockwise and tightened the other two clockwise. However the flow meter does not move/respond to the water flow which is exiting into my bucket without sputtering/air.
For reference I'm filling via the flow meter portion and draining via the actuator portion of the manifold
Getting some where, but can only partially fill the flow meters before the pressure blows the filling pipe off (despite it draining out the other side).
I've turned the main valves back on and got pump running to call for heat, actuators working but the flow meters just zero response, stuck showing 0 flow
Reply to the thread, titled "UFH not working - suspect issues at manifold" which is posted in UK Plumbers Forums on Plumbers Forums.
Mjward,
MOSSEP,
