View the thread, titled "Under Floor Heating not working" which is posted in Gaining Plumbing Experience on UK Plumbers Forums.
Are you sure? I thought the bottom one was because its also called a underfloor control system wired?
I'm learning a lot here. The unit you have describes is a floating action mixing controller. The unit I describe is the control system which receives all the signals from the thermostats. So am I right now that the one I described is the one you mean? I'm only trying to help as you are limited to know what systems have I Installed.
Hi. Fixed it myself. I took the cover of the unit I described and there seemed to be reset button and I just pressed that. Thanks for all your help.
Thats an esbe 3 way blending valve with the unit above being a weather compensator made by Tecmar in the US. I have found that once you need to reset the Tecmar unit they can have a very short lifesapn. Last time i checked (4-5 years ago) they do recondition them (if you can send it and be without).
Hope its all ok.
Reply to the thread, titled "Under Floor Heating not working" which is posted in Gaining Plumbing Experience on Plumbers Forums.
