I've installed nuheat underfloor through my house. It doesn't seem great in that you can feel were the pipes are so you get hot and cold lines across the floor surface. That said I haven't had it on for more than about 8 hours but I would have thought this would be enough to warm the whole floor?
The other question is the boiler does a small circuit about 6 meters in total. This just does a loop and the underfloor manifold comes off of that loop.
I have set set the boiler stay at about 60 degrees. The design flow temp is 55 at the flow manifold.
i have got a Glowworm combo and wondering if it has as delay on it so it's not cutting in and out a lot on such a small circuit and if it has would it be worth setting up?
finally, when I replace the boiler does anyone know of a boiler that works well with underfloor or is it all the same? Just thinking some boilers might have an underfloor set up that means it modulates better on a small circuit or something?
Thanks !
Thanks !
