N
Nordio
I want to install radiators and ufh on the same floor with a compensator controller with 1 mixing valve with room influence and outdoor reset supplying both the rads and ufh combined.
What I was thinking was sizing the rads for a heat pump install. Thats 50 flow and 40 return.
Underfloor loops adjusted for 10c drop also.
Then set the compensator curve to suit the ufh. Though perhaps a bit steeper.
Zone valve on the ufh so that I can operate it independantly and also to shut the flow off on a signal from a floor sensor when the floor temperarture in an occupied area reaches 29c to prevent floor over heat.
What do the experts think? Has this ever been done? What problems am I likely to encounter?
Thanks.
Thanks.
