Dec 4, 2019
44
General Plumber
I have a job putting an unvented cylinder in loft, (I’m G3) but they have open vented heating. I’m wondering if this will be possible as flow into cylinder will be higher than f and e tank. Worries about pumping over, any thoughts? Convert heating to close system first?
Sealing the system is not the only way. You could lift the F & E tank above the cylinder. Sealing a system is all well and good but not the only way and not always an option.
  • Agree
Reactions: SJB060685
I agree you could raise the tank above the cylinder if theres room but I suggested sealing it because hes in the loft anyway and might as well do away with it and free up some space.
Ive installed sealed heat pump systems and others with a plate and many other variations and configurations. I was mere pointing the (sealing the system) was not the only way
