Sep 24, 2019
15
DIY or Homeowner
Hi, I've moved into a flat which has an unvented hot water system and have been told by 3 different plumbers (only 1 has g3) that there's no need to service it. Is this correct?
I've also just noticed water leaking from underneath the expansion tank and been told this isn't a serviceable part so will need replacing. Is this true and how much should I expect to pay?
Thanks in advance
no incorrect needs to be done yearly
as for the repair dont know havent seen it sorry best get a couple of prices etc
Thanks for your reply.
Could you tell me what an unvented service would consist of please because the plumber told me there's nothing to really check
Engineers can't really provide such guidance so easily. Why did the plumbers say it doesn't need servicing? And why three of them? Are you struggling to get somebody to actually come and have a look at it?
The plumber who fitted it was quite abrupt and said he hasn't got time to service it. I spoke with 2 other plumbers (who don't have g3) which said it didn't really need servicing, just check black plastic cone shape section isn't wet inside. Spoke to another plumber a couple of days ago who says he has g3 and he also said that there's nothing to really service. I'm confused
I can see your reasoning for asking then.
It's over my head to be fair I'm not an engineer.
Frustrating that the guy who fitted it couldn't service it!!
Post a thread here with enough detail as possible. And area etc. Leave contact info out and just to private messaging. Agencies scour the forum.
It's more like a safety check tbh. For the system to work safely it has to operate at certain pressures and have correctly working controls installed in the correct way. Cleaning the strainer, checking supply pressure setting, safety devices operate, expansion vessels are charged etc... Some areas with hard water may need immersion descaling. The cylinders instructions will give you advise on maintenance.
Reactions: Stigster and Stu-B
Thank you. That was very helpful
V
UK Plumbers Forums
Deleted member 120897
N
2K
UK Plumbers Forums
Novice needs help
N
J
J
