R
Rachael1278
Hi, I’ve purchased a new build property and had a few issues with the unvented hot water system. I’ve now asked the developer, builder and plumber for proof of G3 certificate of the plumbers but have been told they have no need to show me this. I’ve searched the gas safe register and it’s not showing on their profile, however this doesn’t tell me definitely that they do not hold the qualification.
Anybody know what I can do to check this? Building control who signed off the house are basically unhelpful/uninterested.
OK, just post the photo when you're back.
Hope this helps
Normally fitted to bathrooms / taps the other end of the house / far away from the cylinder as you have to run the hot tap for a while to get hot water due to the distance and the cold water in the pipe as it’s unlagged/ gone cold etc
You haven't got the valve I wanted to see but never mind. Once you have closed the valve Shaun asked you to, close the one on the very top of the cylinder too. There should be no water from hot taps after an initial short run off.
Open them both again once you have found out whether it stops running or not.
Evening, the water stopped after the initial run off as you said.
Ah, I am silly aren’t I!! I will try this again now and let you know in the morning
Good morning,
So, the hot water was on from 6-7am, just tried hot water and it’s probably a little warmer but still not hot as it should be.
I did notice that the secondary return pipe where it enters the cylinder was hot to touch when brass valve under the pump was turned off but when I turn it back to open it instantly goes cold. No idea if this means anything.
Thank you.
Reactions: ShaunCorbs
Correct but does the cylinder heat up / you have hotter water, if you do have hotter water that means water is flowing out of your cylinder all the time maybe
Also the red valve on the left wall just higher than the immersion is this open?
So am I to turn of the lever on the top of the cylinder, turn the boiler on, wait a while, turn the lever back to open and test the water temp from the tap?
Red valve to the left is open.
Thank you for your patience
V
UK Plumbers Forums
Deleted member 120897
J
UK Plumbers Forums
N
2K
UK Plumbers Forums
Novice needs help
N
