Guest viewing limit reached
Vaillant ecotec plus 831 problems
View the thread, titled "Vaillant ecotec plus 831 problems" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Did you check the plastic filter that sits in the brass manifold, directly behind the low water sensor? It always blocks and causes hot water issues.
You'd need to remove the low water sensor and flow pipe from the primary heat exchanger to get it out.
Part number is 179030 i think... But might be different for different Ecotec models?
Plastic filter had degraded, I think that was what started the blockage in the first place.
Reply to the thread, titled "Vaillant ecotec plus 831 problems" which is posted in UK Plumbers Forums on Plumbers Forums.
Hobo128,
Hobo128,
