Vaillant Ecotec Pro 28 F28 Fault Code
View the thread, titled "Vaillant Ecotec Pro 28 F28 Fault Code" which is posted in UK Plumbers Forums on UK Plumbers Forums.
F
freebird
Hi, have been out to look at this earlier today. Boiler won't even go through ignition sequence..... Have checked gas supply etc. Boiler is approx. 2 years old and has apparently played up from day 1 with this fault code. Tenant usually presses reset a few times and then fires up. They have a paycard meter and the gas supply went to emergency credit - but now has credit again......
Any ideas??
Many thanks
Yep you need a gas Safe engineer out. Need to read the forum rules mate. Will probably be under warranty if installed legally
Looked pretty sensible to me.
If you are gsr then get your post count upto ten and then send your gas safe details to a moderator so you can gain access to the inner gsr sanctum where gas issues can be discussed openly.
Reply to the thread, titled "Vaillant Ecotec Pro 28 F28 Fault Code" which is posted in UK Plumbers Forums on Plumbers Forums.
freebird,
Dotty,
