Right guys, I'm fitting a Victoria & Albert Roll Top bath tub.
The trap is supplied with the bath, and is a very nice quality metal (chrome plated) assembly.
It's a shallow trap, that then has a chromed pipe that drops at 90 degrees down under the floor boards.
I wanted to attach a mechanical 40mm elbow onto this, to point me in the direction of the outside wall.
I've hit a problem as the chrome pipe is ever so slightly smaller than standard 40mm waste pipe. So the elbow is a sloppy fit. I just know it will leak. I've tried a different brand and it too is sloppy!
So it looks like I might have to make it on and silicon it. Which to me just smacks of 'BODGE'.
I don't really like putting my name to any bodge, even if it is the only solution. Anyone else come across this?
Ta😀
Right, not had many viewings to this thread, so what I'll probably do is call Victoria & Albert technical line and explain problem. Then report back. You never know, it may help some poor plumber who has the same problem one day.
Nightmare!
Ta😀
Nightmare!
