Victoria & Albert Roll Top Bath, HELP!!!
View the thread, titled "Victoria & Albert Roll Top Bath, HELP!!!" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Dannypipe
Subscribed
Right guys, I'm fitting a Victoria & Albert Roll Top bath tub.
The trap is supplied with the bath, and is a very nice quality metal (chrome plated) assembly.
It's a shallow trap, that then has a chromed pipe that drops at 90 degrees down under the floor boards.
I wanted to attach a mechanical 40mm elbow onto this, to point me in the direction of the outside wall.
I've hit a problem as the chrome pipe is ever so slightly smaller than standard 40mm waste pipe. So the elbow is a sloppy fit. I just know it will leak. I've tried a different brand and it too is sloppy!
So it looks like I might have to make it on and silicon it. Which to me just smacks of 'BODGE'.
I don't really like putting my name to any bodge, even if it is the only solution. Anyone else come across this?
Ta😀
Right, not had many viewings to this thread, so what I'll probably do is call Victoria & Albert technical line and explain problem. Then report back. You never know, it may help some poor plumber who has the same problem one day.
Nightmare!
A picture will paint a thousand words. So I'll take one at work tomorrow. It doesn't fit snuggly into the fitting. It's very close.
But you know when you know when you put a piece of standard waste pipe into a mechanical fitting, and tighten the backnut. It pinches the rubber and grips the pipe tight. Well with this, it doesn't. So the pipe will spin and pull out easily. It's just a couple of mm too small. Very frustrating.
Never had this problem before. I'm Semi tempted to just put a standard Mc Alpine shallow trap on the bottom of the bath waste. You can just see it though, and the chrome trap looks fantastic.
could do with a pic as you say, but could you not just buy another chrome trap, more suitable?
shaun
Yeah, I thought of that today. It's just that the client is not the most understanding person, and will assume I'm wasting their money!
I'm working tommorow for my sins, so I will photograph it, and post it up. Trouble is, I wanted it sorted by midweek at the latest. The floor has to go down!
I should have photographed it today!
I've seen a similar trap for £25, which is a lot cheaper that the £95 I think this one cost!
Cheers for the advice. I will post with pics tomorrow.
In the end, I had no choice but to silicon the compression coupling....I've just checked out the link to Mc Alpine posted by Tiddles. That would have been perfect!!
Ironically, the bathroom has now been ripped out. It was a brand new install. However the house went up for sale, and was bought by another customer of mine (what are the chances!?).
He called me round, and said 'the wife loves this bathroom, but due to the layout of the house, we want to turn it into a bedroom and move the bathroom downstairs. So even though it was only a year or so old the bathroom got ripped out!
For your information through. In that year, the joint hadn't failed. In future I know to use the Mc Alpine washer above. However when I asked, no one seemed to have a solution, including several merchants.
No. I can't remember the last time I used a push fit waste fitting. It might well have worked!
I just never use em and thus didn't think of it.
Reply to the thread, titled "Victoria & Albert Roll Top Bath, HELP!!!" which is posted in UK Plumbers Forums on Plumbers Forums.
Dannypipe,
BLOD,
