B
bm1289
Hi Folks,
Need help with Vokera Compact 24 problem l have. when turning boiler on there was a solid red light on. No fan/pump running, No mains voltage at fan, No voltage on pcb fan outlet on board, So decided to change main control board.
After board was changed boiler green light blinking at start up,pump ran,fan started and pressure switch clicked. Still no ignition!
Help!!!!!!
Could it be ignition module or am l missing something?
whats the ignition module set up? and you need to put a meter on the aps just because it clicks does not mean its working
Checked DP on APS, Faulty,Replaced and hey presto boiler fires. Thanks for help Gasman presumed it was ok......Cheers!
Hey bm1289
"Checked DP on APS" what does this mean as I think I have boiler with same same problem.
