Hi all,
I have a 4yr old worcester bosch greenstar 28i combi boiler. The prv keeps kicking in and discharging water. When I first noticed this, I repressurised and bled the system to 2 bar, fired up the heating again and left if to heat up. Within an hour or so the water was dumped and pressure reduced.
Since repeating repressurising the system and firing up again, i have watched the pressure dial increase until it hits 3 or so bar then it dumps....i'm guessing this is the pressure to which the prv is set.
I've been led to believe this problem could be caused by the expansion vessel. If so, is this a common fault? And can it be remedied by increasing the pressure of the vessel? Hoping it won't need replacing :s
I have to confess, i noticed this in March, and have left it as one of those things to get sorted. . . dunno if it could have been caused by the cold winter as my boiler is in my cellar.
Any advice on how to remedy this would be much appreciated. I am an nvq level 2 plumber so feel i could fix myself if not too complex a problem.
Thanks for reading!
Thanks for reading!
