W/m waste hose connection
View the thread, titled "W/m waste hose connection" which is posted in UK Plumbers Forums on UK Plumbers Forums.
jaydebruyne
Stupid question time...
Is there any reason you wouldn't connect a w/m to a p-trap with an appliance spigot connected to the half bowl on a 1.5 bowl kitchen sink?????
I'll explain when I get some answers...
I'm intrigued but I'll say no as I've done it. (Cowers waiting for barrage of abuse)
Well.. A colleague me told me I shouldnt have done it as the half bowl is too small :/ first time I've heard that one!! He also said that because the underside of the bowl is higher than the main bowl, it can't handle the volume of water pumping out from a w/m
No issue really. If it has a single trap & both bowls going into it, then no issue where the waste spigot goes whether below the half or full sink bowls.
Only thing I think of is if it has separate traps, then the smaller bowl trap can tend to be blocked with vegetable waste easily.
Any water noise will be as bad in either bowl
What tosh, was he a plumber, this college of yours?
As above it's the trap not the bowl that handles the volume of water from the machine.
Most plumber would agree that the up-stand W/M trap with it's built in air gap & single use is the best way but the spigots are OK bar the additional risk of blocking, so long as the hose is raised up above the over spill level of the machine to guard against siphoning out.
He said it and I thought, this doesn't make sense... Then I doubted myself so thought I'd post it to clarify
You should've said to your mate if it did ever fill the 1/2 bowl it would simply pour into the main bowl haha, sometimes the waste kit under the sink for a one n a half bowl sink usually has the trap at the main bowl side but it's all interconnected so he's speaking poops,
Back flow and glugging as spigot is usually above trap. If traps blocked with fat.......
Reply to the thread, titled "W/m waste hose connection" which is posted in UK Plumbers Forums on Plumbers Forums.
jaydebruyne,
Ermintrude,
