WHPES
4,830
590
113
North Yorkshire
First for me - a customer has requested a wall hung WC. The catalogue shows mounting frames for use in false walls, however this one is to go directly onto solid masonry with the cistern and waste in a void behind. What fixings to I need in such circumstance?
They normally come with fixings mate
You probably will have to chase in some brackets. Never fitted one, but MI's should have answers. Interested to know, though.
How thick is the wall? I presume a single brick or block? If so, fit the brackets (read 'long bolts' through the wall and drill the holes for the soil and flush pipes. You can get a cistern for about £60 which will marry up to this on the other side of the wall.
Job done.
Get a geberit frame and you can get extensions for waste ect didn't read post corectly not realy designed for solid Walls the way you have to do it without frame more for stud
But if you have to use no frame
10x120 fisher fixings will do it but make sure some form of rubber is used between wall and pan when tightening agaist wall or could brake easy
IMO you don't want anything between the wall and pan as it will create a pinch point. All you need on the pan side is the usual fixings.
Be VERY VERY careful about bolting directly to a wall, unless the wall is very solid and the fixings are very good AND designed for the pan you will likely get problems. Definately talk to the pan manufacturer and follow there advice. I'm not saying you couldn't do it but its not one that you want to be making up as you go along.
Job done.
done one like this but made 4 plates 3mm thk steel and put on either side of wall on wc side sunk into plaster to spread the load.
ant
