pintvan
Re: Warm Front botched up install. Ideal Icos broken now for 3 months - vulnerable x
Definitely agree that I should have kept the old boiler and the old pipework. It worked great and was done by a local plumber..so what if I saved £100 a year on a more efficient system.
If it was a straight agreement with T&C's to an installation company then I wouldnt hesitate, but as the Government(DECC)/EAGA/EAGAHEAT/WARMFRONT/IGUANA/CARILLION are involved, I can see potentially see the ball being kicked around for months or years and nobody taking responsibility.
At least the weather has improved!
air separator is not need if cold fed and expansion are like 150mm from each other , aav on open vent are good thing if pump sucks air should there be not enough head ! but customers with old ch systems that have not been looked after for 10-15years and then they decide to go for new boiler and rads some times they will have to face the bill of repiping the central heating as system is not piped sized correct in the first place + I am sure that they have double the size of the rads which will not help ! Solution is , get someone to Survey the job and pay the £1200 fee and take them to court an see , when you finish call some one to put system correct
gas pipe been 15mm will not stop your house from been toasted
