View the thread, titled "Waste Connection to old Belfast Sinks" which is posted in UK Plumbers Forums on UK Plumbers Forums.
A
arco
Hello
I have two reclaimed Belfast sinks to fit in a kitchen, but am having problems finding a solution to connect the sinks' waste outlets (threaded metal,one with an OD of 52mm, one with an OD of 46mm) to modern 40mm pipe and plastic compression fittings. Any advice gratefully received!
arco
Have a look at the rubber "fernco" type couplings that use jubilee clips to tighten down, they are very flexible and will stretch/shrink quite a lot.
Thanks both - I have ordered 2 of the fernco couplings that Nick recommended, and hopefully they will do the trick.
Arco
Reply to the thread, titled "Waste Connection to old Belfast Sinks" which is posted in UK Plumbers Forums on Plumbers Forums.
