water help no hot water
View the thread, titled "water help no hot water" which is posted in Bathroom Advice on UK Plumbers Forums.
hi we have an issue with our heating and water system . new flow switch and new pump , system bled , all done by a professional but still no hot water or heating. when the plumber left yesterday we had boiling radiators and some hot water although the heating was switched off. my suspicion is diverter valve but unsure as to why nothing is working again now. boiler tries to kick in but says FD error (flow)
would be really happy for some advice as we have been 4 weeks without hot water no and the Mrs isn't happy.
thanks in advance
John
Well unfortunately the saga continues, everything worked great Friday Saturday Sunday Monday then as we got up this morning FD error back on boiler. Give them their due plumbers back out today but couldn't get it going. They are thinking heat exchanger but won't commit till boiler stripped as as you all know they are expensive.😱
Restating testing mentioned earlier.
Switch demand for heating and hot water off on programmer and turn down both thermostats.
Now switch off power to the entire system using the spur box.
The 3 port should move to hot water setting.
Now select hot water on programmer and turn cyl thermostat up.
The 3 port should remain at hot water setting and boiler and pump should start.
Now switch hot water off on programmer and turn down cyl thermostat. Boiler and pump should stop , the pump may run on for a few minutes after the boiler stops.
Now turn on demand for heating and turn the room thermostat up.
The 3 port should move to heating and the boiler and pump should start.
Now, request hot water and turn up the cylinder thermostat.
The 3 port should move to the middle position.
Post the results of the 3 tests here which would help diagnostics.
[automerge]1565728607[/automerge]
Obviously, switch on the mains to do the testing - missed the step oops
[automerge]1565728771[/automerge]
Sorry just got the previous update - after I posted.
Just ignore
Righty ho this is the latest, blocked heat exchanger, plumbers today have managed to unblock part of it but it's buggered really, short term fix very short term so we are having a new boiler fitted next week or week after as it will give us 10 year warranty. Could just just change heat exchanger but we will feel better with new boiler.
Glad you finally got to the bottom of it
Hi John,
I suggest getting your professional plumber back if he/she has supposedly fixed it?
What boiler is it?
By looking at your question it sounds to me that the accuator on top of the 3way valve is giving trouble or faulty or your programmer is possibly faulty but if the boiler is fireing you should be able to turn on the valve manually to hot water but you can check all this if you have some electricial knowledge and you should not of let this guy out of your home when he was asked to fix it no point in throughing money away
Reply to the thread, titled "water help no hot water" which is posted in Bathroom Advice on Plumbers Forums.
jpbroad1970,
DAVE01,
