R
redapple
Hi
I was hoping I might be able to get some help with my wiring center.
I had the following setup:
-Very Old E-type Boiler
-4 zones, ( DHW, Ch1, Ch2, Ch3)
- 4 Channel Programmer
- Unvented Cyclinder
- Grundfoss pump selectric
- 3 thermostats for each of the Ch's (Salus RT200 no neutral connection required, Just SL and L)
System was working fine no problems. But I recently had to get my boiler changed as the old e-type died.
I decided to replace it with a Worchester Bosch 30CDI Floor Standing Boiler. The Plumber who was recommended by a friend installed the boiler and everything went OK, apart from a few location hiccups ( He is Gas Safe checked his number out). After installing the boiler and checking that it worked he also installed a new Grundfoss Alpha 2 15/60 pump. Heated up the cylinder and rads no problems.
But when he opened up the junction box to do the wiring he got afraid as the wiring was like a plate of spaghetti, with wires
connected to separate connector blocks instead of one terminal strip with no labeling. He said he would not be able to do the wiring. I have tried to contact the original plumber who wired the system up but have not been able to get through to him.
I am not bad with electronics thought I would have a go at wiring it up. I labelled everything and here is is what the original wiring looks like: Connector block 5 is the boiler to pump connection which is not shown.
Uploaded with ImageShack.us
I would like to create one terminal strip to make life easier. Here is how I would rewire it. I have not included the cylinder stat connection or DHW valve and Programmer Com 1 connection as I not sure it all goes together or another connector block is required.
Any help would be much appreciated.
