View the thread, titled "WC move" which is posted in UK Plumbers Forums on UK Plumbers Forums.
M
MrT
Hi
I have had a request whilst fitting a new toilet if it can be moved slightly to the left a little as it is v close to the wall at present and your knees knock the radiator!!!!
Is there a way of doing this with a pan connector - a flexi one wouldn't do it as it only needs moving 6 inches or so and i dont like flexi pan connectors anyway.
Is there a fitting out there that does the job or a combination of two that would do it?😀
thanks
I now what you mean about flexible pan connectors,they can be abused,have seen some right strange connections
however what you have in mind just moving pan over,they are ideal
Sorry puddle I disagree with you mate 6" is too much of a bend and ribs collect to much solids with these it's easy and cheap enough with 2 bent pc's one long and cut down if needed but it's £10 tops.Cheers John
From that link 2 s221's (cut down)and maybe a need for a s226 would suit.And 90's swivel both ways so vertical or horizontal soil makes no difference.
sorry - yes it is a horizontal waste - will try the 2 bent ones (ooh er!!!)
Thanks chaps
Reply to the thread, titled "WC move" which is posted in UK Plumbers Forums on Plumbers Forums.
