C
chrisc1980
Hi I have a loose toilet seat and when I tried to tighten well nuts one of them won't tighten. Is there anyway to replace these well nuts or am I doing something wrong??
Just googled well nut and it`s a fixing for back to the wall toilet pan.
It`s a 2 part fixing and it`s on fleabay for £4 & free postage. Being a M6 thread I guess the thread has stripped on one of the parts.
You have a rubber bush that expands as the screw is tightened so it could be a stripped thread or the rubber bush is worn and not gripping inside the blind hole. If you can remove it and degrease the rubber and the hole it fits in it might then work but for £4 I`d just replace them both.
C
Boiler Advice Forum
Deleted member 120897
