What boiler do I need? (Ideal Logic boilers)
View the thread, titled "What boiler do I need? (Ideal Logic boilers)" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Hi all,
I'm just about to buy a new build house. The building company has changed their boiler set up from having a cylinder to a combi and I'm really worried it's a ciat things and I'm going to get a system that struggles more with the house size. I've attached drawings of the house which has 4 beds, two thermostatic showers and other rooms and radiators as shown.
The company are installing ideal logic boilers which I don't have a choice on that make. However, I want to know which of the ideal logic boilers are right for this house?
I also want to extend to a 5th bedroom and extra bathroom at some point so want to know if this would make a difference to the ideal logic boiler chosen.
Neil
Without looking at the plans, they're not doing it for your benefit but to cut costs and Ideal do not make a storage combi afaik which may be okay for multiple shower/bathrooms. Irrespective of boiler size, heating capacity should not be an issue with a new build it's the hot water delivery that should concern you especially if you have plans to add another bathroom.
Hi thanks. What do you mean by delivery system? Sorry I'm a layman at this. Thanks for your help
Hot water delivery ie. the ability of your system to provide HW and in your case potentially for 3 + outlets.
As I said being able to heat your house isn't a problem but providing enough hot water at a decent flow rate might. That said the 40kw Ideal vogue can provide HW @ 16.4 l/m (not confirmed) and it might be enough although if I were you I'd negotiate with the house builder and have an unvented cylinder installed or get legal with them about changing the agreed spec.
Ok. Thanks get it. So ultimately, the tank would remove any doubt because with would have the capacity to cope. I think I'll challenge them.
Reply to the thread, titled "What boiler do I need? (Ideal Logic boilers)" which is posted in Boiler Advice Forum on Plumbers Forums.
Jarvo273,
Jarvo273,
