Hi guys. I have a leaking hot water tank indirect connection. It seems to be just the washer/seal right on the tank surface crumbling. I'm fine to loosen that and refit with Hemp and something like Boss White, (yes, I am aware of the non-potable aspect), but I wondered if breaking down the whole joint and refitting with a new seal might be the better strategy.
It shouldn't be too onerous a job as both the hot water feed and central heating/water feed (3-way valve system) are gate valved and can be isolated just above the tank. Which would be the better way to go?
If the more correct job is to break the whole thing and fit a new washer, what size will that washer be? The picture shows the joint assembly, and the pipe feeding into the outer part of that joint is 22mm of course. The joint is made up of:
A - 22mm pipe
B - 22mm compression joint onto...
C - Larger fitting (not worked with this before so no idea of inner size or name)
D - Larger nut behind C to compress to tank
E - Displaced and crumbling fibre washer
What size would that replacement washer be, or does it need to be removed and individually measured?
A - 22mm pipe
