What we all working on this week ?
View the thread, titled "What we all working on this week ?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
king of pipes
Subscribed
I have a insurance job to try and rescue a poorly installed quad shower the customer wants to save the tiling if possible and has a few spare so fingers crossed it may work , the loss adjuster allowed em £1500 that will just about cover materials. Kop
From the Eurocarparts ebay shop, £19.99 wit free p&p and it had a 20% off when you use POCKET20 discount code on the checkout page.
Portable Power Pump Pressure Washer Car / Caravan / Motor Ho 5026637621796 | eBay - https://www.ebay.co.uk/itm/233467701812
Yep thats the one mate makes servicing that bit easier and more controllable
[automerge]1599278510[/automerge]
Earth pins mate. Holding the insulation in place. After 9 years would be surprised if they weren’t down to little stubs.
[automerge]1599257462[/automerge]
What litre is yours mate?
No mate they were in a state bud cleaned up fine , electrodes were a bit bent tried cleaning them bud and straightening em but i changed them in the end they needed doing in all honesty the new spark electrode is different shape now.
My power washer is the 8 litre one H not super powerful but ideal for these jobs and controllable no need to use the customers water .
Newcastle mate. Grandads 80th.
I was going to say Newcastle, but didn’t want to look a tit and it be like London 😂
[automerge]1599320396[/automerge]
self employment bud is where you should be aiming , i worked for companies for 30 + years making others wealthy before i took the plunge its now 9 years and haven't looked back always busy and my own boss jobs get done right,
Where did you find best for experience mate?
You just pick it up mate as you go along I did a few manufacturers courses you just get to know the faults on certain boilers, it's often a process of elimination the flow charts in the manual along with the fault codes , it's worth learning how to use a multimeter property aswell , you tube is also useful if you're struggling and as a learning aid . Regards Kop
First fix for this later in the week, plus a home made towel warmer.
[automerge]1599558048[/automerge]
Look at the joists on that 🤣
[automerge]1599558049[/automerge]
I’m chilling here this weekend. Lovely weather this morning.
Geordie land, The Toon...... lived there for 30 yrs 😀
[automerge]1599687113[/automerge]
Coal fired?
12" or more Simon?
Does the filling loop bolt straight onto the sprayer handle or is there a fitting/fittings you use?
No mate remove the standard Lance what these come with the attach a piece of clear polythene tube with a jubilee clip , the connection to the filling loop or rad is a short length of 15 mm pipe warm the ploythene tube insert the tube again fit a jubilee clip then adapt to suit your application. Cheers kop 😉
Thanks, that should save some time on some jobs. Will have a riffle through of my boxes of tubing from my fish keeping days at the weekend, should have something in there that would be do the trick.
A bathroom modification for a elderly gent with a dodgy ticker, believe it or not I installed this 17 years ago when it was first built , I can't believe it was so long ago removed the bath, tiling ect and found loose plasterwork and cement render which had to come off revealing a couple of nasty cracks. These were ground out the whole wall sealed with SBR and repaired with Fisher resin the area was then dot and dabbed with new plasterboard , formed a new boxing to house the first fix shower pipework again plasterboarded ready to fit Multipanel later on , now have a 5 day break so till later chaps 😁😁. Kop
Nothing as exciting. First fixing that barrel sink and copper towel warmer.
[automerge]1599829893[/automerge]
That'll do.
Reply to the thread, titled "What we all working on this week ?" which is posted in UK Plumbers Forums on Plumbers Forums.
king of pipes,
Chuck,
