What we all working on this week ?
View the thread, titled "What we all working on this week ?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
king of pipes
Subscribed
I have a insurance job to try and rescue a poorly installed quad shower the customer wants to save the tiling if possible and has a few spare so fingers crossed it may work , the loss adjuster allowed em £1500 that will just about cover materials. Kop
Was it under warranty?
How are they replaced?
These were wired to a plug so can’t just swap with a standard 2 port
Yes Scott was replaced under warranty complete with wiring and plug personally i wouldn't use one again i would make my own one up, looks like they have changed the valves now bud 😉. Kop
Thanks for the heads up.
I was quite impressed with the setup, comes with honeywell valves and the wiring centre made it easy to connect, I didnt need to involve an electrician. Could have done with lockshield/gate valve on the hot water return to throttle it down a bit but no space to cut one in.
Cost less to buy the pre plumbed than a standard cylinder and all the bits.
Yes mate good value for what you get but caused me alot of grief the job was 2 hours from home and 3 visits to get it sorted pi--ed right off 😜
I hate those ESI valves. I have fitted a couple of those cylinders which come with them and both have had a valve which has leaked from the spindle in about 2 years. Not impressed.
Ensuite shower room upgrade bit of a mission removing the multi panel and it's hiding up a multitude of sins . Kop
Putting it all back together strengthening the metal stud wall plenty of timber for fixings for later, damaged dot and dab removed and replaced, toilet frame fitted drainage altered to suit stud work done ready for ply.
Me knees 😀 not bad for a day and a half still hate plastic
Finished a little oil boiler install.
Reply to the thread, titled "What we all working on this week ?" which is posted in UK Plumbers Forums on Plumbers Forums.
king of pipes,
Chuck,
