T
The_Tonk
On a job this week changing bath and basin and retiling bathroom.
Old bath and basin out new bath in and water back on, fill bath ready to start tiling, turn tap off, hear a hissing noise coming from where basin has been removed, think one of the caps may be loose but when checking water found to be coming from below floor. water back off floorboard up leak found.
Section of pipe removed, and on inspection the pipe is found to be corroded and a small hole has formed.
(Pipe all green where flux has not been cleaned off when pipe work was installed many years ago)
Hole in pipe was not directly cause by me but the badly corroded pipe has failed possibly with the pressure of the water going back on or due to adjusting pipe work above floor when fitting new bath.
Section of pipe replaced water back on and tested, all good.
Neighbour in house below returned from their holiday and complained saying there bedroom below was soaked, carpets and curtains wet, ceiling all stained and cracked!
Not convinced this to be the case I asked to see damage, not to happy with my request they finally let me in to see. Only damage found was 3 or 4 damp marks on ceiling about the size of a 50p coin. Convinced her ceiling is going to fall down neighbour has said they plan to call her insurance.
Would of liked to get a closer look from a ladder but the neighbour was not having it and just wants to contact insurance. From the floor level the ceiling looks ok no other damage/sign of water was found. carpets dry. (was around 24hrs after burst pipe).
If this happened to you would you view it as your fault?
What about the neighbour? (I would guess repainting ceiling should fix)
Water was only back on for no more than a few minutes before leak was found.
