wow, cheers for that. an interesting read for sure.
thinking of draining in the next couple of days.
some more questions!
1. to do a flush is it best to drain down and refill (which before has settled sludge in pipes and blocked them), or do what i did before and drain from the bottom rad but with the expansion tank still adding water, until it runs clear from the bottom rad, then stop draining, run heating to stir it all up, then run drain hose again until clear. repeat until it runs clear almost straight away. also means u get no airlocks.
2. not suggesting i will, but what would happen if u put normal household descaler in your system?
What I do is to flus thru with mains water first (if its easy) otherwise drain down fully. Refill with clean water & add sludge remover. After reading Flyboy, I'm going to keep doing that as I always thought that this will get rid of the easy stuff & allow the expensive chemical to work on the tougher stuff.
Power flush (I'm planning to get the MagnaClean powerflush thing when cash flow allows). While its flushing, wollop the rads with trusty rubber mallet to dislodge the crud.
Drain, refill, flush thru with mains water thru each rad individually.
Refill & add inhibitor.
