Because my Wife is concerned that if the Loo is flushed when the Washing Machine is on or filling, the WC will *rob the Washing Machine, thus throwing it out of kilter in some way.In a normal house on mains water supply the answer should yes. Why are you asking?
Our Water Pressure is completely normal, it is just that my wife feels if the loo is flushed or the bath is run at the same time as the Washing Machine is filling or running, the other appliances will *rob the Washing Machine and it will not work properly.Depends on your incoming water pressure and flow if it’s low then no I wouldn’t use anything when the washing machine is on it’s full cycle
