Which core drill set?
View the thread, titled "Which core drill set?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Jennie
Hi all,
I need to buy a core drill set (4inch, inch1/2, inch1/4) to use with my SDS drill.
What sets would you recommend? I'm after something reasonably good - probably diamond tipped. But reasonably priced.
Thanks everyone,
Jennie
Hi all,
Thanks everyone,
Jennie
Hi Jennie,
I hope you will have as well some sort of clutch on your sds otherwise it will rip your arm off.
I've always used my colleagues drill bits in the past. But now the time has come to get my own.
I do not know what's the price range but I can recommend spectrum mbx5 diamond core drill set. It ain't cheap but i think good tools shouldn't. I think could get also some cheaper sets but do not know what's the quality like.
The Erbauer set is ok for the price but again it depends on how often you use the core drill set. If it's 3/4 times a year then it will be ok to go cheaper.
Rothenburger do a set for about £100 Plumbase usely have them in, depends how much drilling you intend doing had mine a couple of years & been OK.
Don't waste Yer money on the rothenberger set, it will last less than 6 months of light use and look like a toothless hag! Better off buying a cheap set fer fifty quid off the pikey vans that go round the site and believe it or not, for a change the pikeys won't be robbing Yer!!!!!!!
Reply to the thread, titled "Which core drill set?" which is posted in UK Plumbers Forums on Plumbers Forums.
Jennie,
unguided1,
