R
Rolf_Mason
So...
At the end of 2008 (early December, so about 4.5 years ago). We had central heating installed for the first time. An Ideal Isar HE24 Combi boiler. Not long after we had to replace the PCB (a well documented fault with the old black PCBs meant it burnt out. We now have an orange PCB).
About four weeks ago the DHW stopped working on our Ideal Isar HE24 Combi Boiler. CH was working fine, albeit a little erratically - starting up despite the connected remote thermostat being off (Siemens RDJ10RF).
We got a good Plumber recommendation, who came out to look at the system.
He diagnosed a knackered diverter due to the system not getting cleaned out since installation (Yes - I've learnt my lesson there).
He replaced the diverter and the system seemed to work fine...for a day!The DHW went again.
The plumber suggested it was the level of sludge in the system that was causing the diverter pin to stick, so he came and completed a full flush of the system: putting in cleanant, leaving it for a couple of days, returning and flushing the system til clean, and then adding some softener to stop the sluge build up.
However, six days later the DHW went another time. Water pressure had dropped below 1, and this time the PCB showed the error code L9, which from the installation/service manual and online forums is a possible block in the heat exchange (or a pump problem).
On the morning of 28 May (after advice from plumber and online forums) I simply turned the boiler off, topped up the water pressure, and reset the boiler. This worked and we got hot water once again.
But then overnight from Friday 31 May into Saturday 1 June, the boiler stopped working, again with an L9 code. When I tried to reset it nothing happened, apart from the L9 code changing to the three lines on top of one another (like a 3 without the side bar).
Later in the day we discovered a significant leak from the boiler, which yesterday the plumber identified as coming from the Heat Exchanger.
So...clearly we have a significant (and costly) problem. Here are my questions:
1. How much might we look to spend on a new Heat Exchanger?
2. How long does this job typically take?
3. Why might this have happened?
4. Might the other works have caused this problem?
5. Should this problem develop in less than 4 years on the boiler?
What cleanser was used? Anything to acidic will eat the aluminium heat exchanger. Not sure if ideal do fixed fee repairs or not, might be worth a second opinion. They are rubbish boilers but not helped by the way a lot of them were installed.
Ive got one coming up soon and said I want at least 4 hours.
As long as the nut bolts etc are in good condition it will be about a 4 hour job. If the nuts etc are in a poor condition you probably wont get it out so just replace.
It will cost a fortune to fix I would recommend replacing the whole boiler. It is not uncommon for these boilers to be replaced at this age I took a 2 year old one out due to constantly breaking down.
As said above, rubbish boiler, we have taken several out, its common to have a new pcb every 2 years whether it is black or orange, a lot of these boilers were fitted by an equally rubbish scheme called warmfront, by an equally rubbish company called Eaga (now Carrillion owned) the systems were rarely cleaned and this just makes for more problems, in short dispose of the boiler and get a decent one Im afraid.
These are my opinions, not the opinion of the forum operators.
Its going to cost a fair bit I'm afraid. A heat engine, as they are called for this boiler, costs upwards of £400.
Ideal Heat Engine Kit - Isar He/icos Syst He | 173554 | Ideal - Product
It usually takes 3-4 hours to change one, depending on how far gone it is. Also sounds like it is interfering with some electrical components, so potentially more cost again.
Personally, I wouldn't throw any more money at it. Plenty of boilers around that come with a 5 year warranty now, I'd pay a bit more and replace it myself.
V
UK Plumbers Forums
Deleted member 120897
